964 G50 vs 3.2 G50
hi everyone.
I was wondering if there is any technical difference between a 964 G50 and a 3.2 Carrera G50?
Are they interchangable? I have driven both and felt that the 964 G50 has a shorter shift travel, is that right?
Carson
For every problem, there is an opportunity
Old 09-17-2013, 11:54 PM
Anyone?
Old 07-24-2014, 03:54 PM
I think the trans is the same. The shift linkage was improved in the 964 compared to the earlier car, which would explain the shift feel. There was also a clutch release mechanism redesign around 1990 and the flywheel was also redesigned to a heavier dual mass unit also around 1990
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 08-01-2014, 09:20 AM
gearhead
According to the marketing the 964 was something like 80% new. Completely different chassis, suspension, brakes, and engine on the 964.
To your more direct question, one thing largely unchanged was the gearbox design. However, the 964 end cover was lengthened and the mounting was changed. The feel of the two gearboxes would be different due to those differences, and the rest of the shift assembly as it mounts in the newer chassis. While the internal function of the gearbox was basically unchanged, what did change was the linkages themselves and how and where they mount in the car. I would expect them to feel similar but not identical.
Furthermore, you could have driven a car with the factory optional short shifter. That would make a dramatic difference in feel.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-01-2014, 12:25 PM
