993 Piston upgrade on race car
Looks like my standard 993 eninge with standard 993 pistons are worn on my 911SC racec ,running on 50mm PMO's with slightly more aggressive cam you can run with standard pistons .
Question -as I am now facing engine out with the view of new P/C what do you guys believe is a good option ,bearing in mind i am still running 915 close ratio box.
Is is easy to turn into 3.8 ? or can you buy more race style 3.6 pistons ?
look forward to great advice cheers Dave
Old 10-23-2014, 08:40 PM
Check in with the guys at EBC on some options. Also rennlist 993 forum may have more "viewers".
Old 10-24-2014, 08:49 AM
thank you for info
Old 10-27-2014, 01:50 PM
Skunk works
JV911SYDNEY's Avatar
Easy? Yes. Cheap? No
3.8 pistons and cylinders start at $5k
The less expensive option is to get higher compression 3.6 pistons i.e. JEs, assuming the cylinders are ok
You might also want to run more aggressive cams, which the new pistons would allow, RS valves, ported heads and have carbs rejetted and tuned.
All depends on your budget, what can be reused and possible racing regulations. Get a good engine builder to put together a package so the new parts compliment each other. You can have all top dollar parts but if they don't work together you won't make the power or have max reliability and drivability
964 RS-4
Old 10-28-2014, 12:47 AM
Sboxin's Avatar
We did a 3.6 to 3.8 and found EBS Porsche Racing Parts : Engine Performance Parts : Brake Parts : Used Porsche 356 : 911 : 912 : 914 : 944 : Porsche Boxster Parts : EBS Racing Inc. in Nevada to be very helpful.
They reconditioned our cylinders and made them 3.8.
We bought JE 3.8 12.5:1 pistons from them and their own valve springs.
The engine runs great. But . . . we had to do a 915 rebuild shortly after . . . LOL!
You have lots of options . . . and there is plenty of Forum info on this upgrade . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 10-28-2014, 03:02 PM
txhokie4life's Avatar
Quote de rsrdave
Regards,
Are you able to run pump gas with the 12.5 CR?
What cams did you use?
Thx,
Mike
Old 10-28-2014, 10:12 PM
Sboxin's Avatar
Thx,
Mike
Mike,
We have been running 100 unleaded more to cool the heads than for power - same when we had the stock 3.2L in the car. The 3.8 12.5 engine was tuned by Steve Wong
on the dyno while using the 100 -- but the 964 engine does have a knock sensor system also. You might be able to run pump 91 - the 964 stock engine I think has 11.5CR (?)
We had the 964 cams reground by WebCams to 20-21 high torque rather than high HP.
Of course we also have a custom exhaust system.
Regards,
Old 10-29-2014, 08:00 AM
Thanks Guys for info on upgrade ,looks like i might need to discuss with EBS
Old 10-29-2014, 02:19 PM
Hi Roy ,is yours a race engine and were ther any other major upgrades ,i guess rods,valves etc cheers Dave
Old 10-29-2014, 02:22 PM
Sboxin's Avatar
Dave,
Yes for racing - - a rebuilt 1992 964 engine --
Heads rebuilt but stock with new valves, guides and EBS valve springs
JE 12.5Cr 3.8L pistons from EBS also
Crank and stock Porsche rods and pistons balanced - ARP rod bolts
rockers reconditioned by WebCams
WebCams 20-21 cams regrind from existing cams
Stock 964 intake system - injectors reconditioned to 100%
Race built headers to single out pipe - loud
This is a thread of our build - and a video of cold idle computer settings that was done by Steve Wong
1992 964 Engine rebuild - reasonable approach?
I wouldn't do the 3.6 to 3.8 upgrade except it cost us zero dollars extra from EBS.
They were reconditioning our cylinders anyway and the pistons were the same price as 3.6L. Don't ask what our final cost was - - just an investment in racing - - but
we did get 6K for the 3.2L . . .
Regards,
Old 10-29-2014, 09:12 PM
Hey Roy ,
thank you for replying and love you engine and thread .cheers Dave
Old 10-30-2014, 12:47 PM
Originally Posted by Sboxin View Post
Mike,
Regards,
If I build out my 3.8 -- I might tune it for E85 -- getting both effective high octane and extra fuel flow -- and thus head cooling.
I have a motec 48 system on the race car -- no knock sensors.
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 10-30-2014, 03:57 PM
