Door Buzzer Won't Stop
Can't figure out why. All doors are closed, checked the door switches and they seem good...still it won't stop - except if I turn on the interior lights - which makes no sense. Is there a fuse or relay I can pull to shut this thing off?
Old 10-25-2014, 12:52 PM
Year and model would be helpful.
Old 10-25-2014, 01:50 PM
bri450sl's Avatar
Did this just suddenly happen? The door switches are very simple, so it's possible one of the two broke. They can push in and out and still be broken. All they need is the inner slider to make contact anywhere. Very inexpensive to replace.
Old 10-25-2014, 06:56 PM
Thanks very much for the replies. The car is a 1989 964. I don't recall when it started. It has been happenng for a few months. Been trying to find an electrical diagram so I can track down the fuse or relay. I'm game to jut unplug the thing.
Old 10-26-2014, 01:20 AM
After I replaced a lock rod, I had a central door lock chime on, in my vehicle. I pulled the door upper panel, off again and checked the wiring, a couple times, the chime stopped.
Old 10-30-2014, 10:54 AM
