993 Piston upgrade on race car
Looks like my standard 993 eninge with standard 993 pistons are worn on my 911SC racec ,running on 50mm PMO's with slightly more aggressive cam you can run with standard pistons .
Question -as I am now facing engine out with the view of new P/C what do you guys believe is a good option ,bearing in mind i am still running 915 close ratio box. Is is easy to turn into 3.8 ? or can you buy more race style 3.6 pistons ? look forward to great advice cheers Dave |
Check in with the guys at EBC on some options. Also rennlist 993 forum may have more "viewers".
thank you for info
Skunk works
3.8 pistons and cylinders start at $5k The less expensive option is to get higher compression 3.6 pistons i.e. JEs, assuming the cylinders are ok You might also want to run more aggressive cams, which the new pistons would allow, RS valves, ported heads and have carbs rejetted and tuned. All depends on your budget, what can be reused and possible racing regulations. Get a good engine builder to put together a package so the new parts compliment each other. You can have all top dollar parts but if they don't work together you won't make the power or have max reliability and drivability
964 RS-4 Last edited by JV911SYDNEY; 10-28-2014 at 01:33 AM.. |
They reconditioned our cylinders and made them 3.8. We bought JE 3.8 12.5:1 pistons from them and their own valve springs. The engine runs great. But . . . we had to do a 915 rebuild shortly after . . . LOL! You have lots of options . . . and there is plenty of Forum info on this upgrade . . . Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
What cams did you use? Thx, Mike |
We have been running 100 unleaded more to cool the heads than for power - same when we had the stock 3.2L in the car. The 3.8 12.5 engine was tuned by Steve Wong on the dyno while using the 100 -- but the 964 engine does have a knock sensor system also. You might be able to run pump 91 - the 964 stock engine I think has 11.5CR (?) We had the 964 cams reground by WebCams to 20-21 high torque rather than high HP. Of course we also have a custom exhaust system. Regards,
Thanks Guys for info on upgrade ,looks like i might need to discuss with EBS
Hi Roy ,is yours a race engine and were ther any other major upgrades ,i guess rods,valves etc cheers Dave
Yes for racing - - a rebuilt 1992 964 engine -- Heads rebuilt but stock with new valves, guides and EBS valve springs JE 12.5Cr 3.8L pistons from EBS also Crank and stock Porsche rods and pistons balanced - ARP rod bolts rockers reconditioned by WebCams WebCams 20-21 cams regrind from existing cams Stock 964 intake system - injectors reconditioned to 100% Race built headers to single out pipe - loud This is a thread of our build - and a video of cold idle computer settings that was done by Steve Wong 1992 964 Engine rebuild - reasonable approach? I wouldn't do the 3.6 to 3.8 upgrade except it cost us zero dollars extra from EBS. They were reconditioning our cylinders anyway and the pistons were the same price as 3.6L. Don't ask what our final cost was - - just an investment in racing - - but we did get 6K for the 3.2L . . . Regards,
Hey Roy ,
thank you for replying and love you engine and thread .cheers Dave |
I have a motec 48 system on the race car -- no knock sensors. Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
