Airbag Fail after window regulator replacement?
I followed the Tech guide article re: window regulator replacement for my 996. Buttoned it all back together but the Airbag Failure red light is now on? I'm sure I reconnected it all correctly.
How can I reset this failure code?SmileWavy |
The battery needs to be disconnected for 20 minutes before disconnecting an air bag or it will set off the light.
A Durametric cable can reset or a $100 trip to the dealer. I had the same problem with a steering wheel removal. |
| All times are GMT -8. The time now is 03:04 AM. |
