-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 Power Window Stopped Working (http://forums.pelicanparts.com/porsche-964-993-technical-forum/861220-964-power-window-stopped-working.html)
dgagne 04-18-2015 03:40 AM
Hi,
I have an 89 964 C4.
One minute driver door power window works, next minute it no longer works.
Passenger door window and power sunroof all still work and all other electronics work fine.
Any thoughts?
I just got the car...is there a safety setting I may have turned on?
Fuse, relay?
Where should I start investigating?
Thanks,
Derek
964TargaC2 04-19-2015 05:51 PM
Try swapping out the switch from passenger window. if that works all you need is a new switch
I advise avoiding the URO brand switches
Jim Richards 04-20-2015 06:46 AM
My experience with this was a bad switch, too.
dgagne 04-21-2015 01:59 AM
Problem solved...it was the pesky switch. Bought two OEM ones from Porsche, now I have a spare for when one of the other two left stops working. Thanks for the tips and suggestions.
Mr. Carrera 04-28-2015 09:12 AM
What's a URO brand switches
964TargaC2 04-28-2015 10:06 AM
URO is the brand of some aftermarket parts of dubious quality at best..
porsche964guy 05-20-2015 10:42 PM
I got URO window switches in my 964 Cab for a year now. They are manufactured just like the OE design. Do not compare the old aftermarket design with the plastic clips. These new URO designs have Metal clips like the OE. The main problem with the old A/M design is that the switch pivots had to be made short to assemble from the top in a one piece housing. It came apart by constant use and the body swelling from summer heat. The URO and OE design have a separate top trim that allows the pivot to be longer to prevent the button from coming loose.
