964 8 way seat woes
Hello All:
I am stuck. I have a driver's seat stuck all the way back in my 91 carrera 2 cab. I believe it is the switch, but now can not get access to the 4 rear allen bolts to liberate the seat from the car.
I read on other threads that you can manually move the seat, but this has only resulted in broken teeth on the plastic gears....Now what do I do? I would like to limit the damage I have already caused.
Thanks in advance for any words of advice or guidance.
Old 05-25-2015, 09:47 AM
Tewfiks, you might also post over on the 911 forum. The 964 power seat visually is very similar if not identical to the late Carreras, so perhaps someone on that forum has some experience with your problem.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 05-25-2015, 10:45 AM
ahead of the curve
Jeff Burger's Avatar
there is a drive cable for both sliders - pull them out of the center front drive mechanism where the gear has broken and try to spin each one manually (figure out which direction will move the seat forward) if they both spin and you can get the seat to move you can manually or with a drill move each side a little at a time . If they don't move have someone wiggle the seat while you try to spin the one that is bound if there is something in the rail jamming it you will need to clear that first. good luck
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 05-27-2015, 04:02 AM
Many thanks. I used the detox and still no action from the switch. Is it as simple as pulling the cables out of the motor?
Next issue will be locating replacement gears. Any thought? Is this a dealer only item?
Old 05-27-2015, 01:30 PM
ahead of the curve
yes the flexible drive shafts are held in by the rubber boots they just pull out
Old 05-27-2015, 03:58 PM
