-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   91 C4 Targa control arms correct part #'s (http://forums.pelicanparts.com/porsche-964-993-technical-forum/870411-91-c4-targa-control-arms-correct-part-s.html)
FredC 06-12-2015 01:24 PM
PET shows part # 964 341 017 06 (left) & 964 341 018 (6) right. I'm looking for replacements & have found 964 341 415 06 ...will this work? has it been superseded & is there a difference between left & right?:eek: Thank you.
Vandit 06-12-2015 05:54 PM
Not sure about the different part numbers.
Regarding differences between left and right, the arms are identical. The only difference is the orientation of the pressed bolt that locates the the ball joint is going to be reversed from left to right arm.
