993 Injector Specs?????
Hi,
Hoping for some help. Are these the correct 993 injector values? 993 Injectors are rated at 233 cc/min (22.17 lb/hr) @ 43.5psi or 261 cc/min (24.9lb/hr) @ 55 psi. Thanks for any help! |
It looks the bosch part is 0 280 150 786. Specs are:
0 280 150 786 Ohms 15.6 cc/min 234 lbs/hr 22 Based on: Porsche 993 Fuel Injector for 1994, 1995, 1996, 1997 and 1998 https://www.injectorrx.com/bosch-fuel-injectors/ |
It is about right.
Thanks for the replies. I will be giving the information to Steve Wong. I am going to try to use 993 injectors with a 964 ECU.
Thanks again for the help.
| All times are GMT -8. The time now is 11:29 AM. |
