-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Engine install question (http://forums.pelicanparts.com/porsche-964-993-technical-forum/873984-engine-install-question.html)
wilson234 07-08-2015 10:07 PM
About to reinstall my engine 964 after replacing all seals and head studs. I also rebuilt the cv with new boots. Would one recommend installing engine then cv axles or cv axles first??? I believe I removed cv axles prior to dropping engine but cannot remember. What's easier?
wesleyc 07-09-2015 07:14 AM
I installed new axles with engine in the car without a clearance issue on my 993. But installing the engine with axles in did add a bit of a clearance issue. If they were out with the engine. I would opt to install them after engine was in place.
porterdog 07-09-2015 06:39 PM
Agree; it's easy to r&r them with the engine in the car. I wouldn't even try the other way.
Hamptonsam 07-10-2015 06:30 PM
Either way should be fine. I have never removed the axles when I have removed the engine. Just secured them out of the way.
Newsboy 07-13-2015 03:03 AM
You can do it with the axles attached. Just go slow, and make sure everything clears.
efhughes3 07-24-2015 06:56 PM
Yes, you can do it either way. But since they are out now, the wise choice would be to install the motor first.
