3.6 compression test
Which spark plugs are easier to remove? I've been reading something top and bottom plugs. Looking to get an idea as to the health of this engine before I dive in.
I would do a "leak down" test, as it will give you a way better idea of your engines internal health. It's pretty much the same amount of labour, but will tell you where your problems are if any, I.e. Intake valves, exhaust valves or rings.
I find the top plugs pretty easy. You'll have plenty of access just by taking off the electric fan blower assembly on the left, and remove the airbox cover and filter on the right. I use a 3/8" ratchet, wobble/u-joint, and a ~4" extension, then the spark plug socket.
Still, if you don't know the history, then it's time to check the valve lash anyway. Which means you'll need to remove all of the bits to get to the bottom set of plugs too. Enjoy! |
| All times are GMT -8. The time now is 09:29 AM. |
