c4 brake lights indicator...
recently my brake lights would go on and off when im in driving mode. I think its a loose wire but im not sure on how to troubleshoot the problem/problems. any information would help.
thanks-sasaki |
Are you talking about the "idiot light" on the dash or your actual brake lights?
1990 - Carrera C-2 - Highly Modified 2002 BMW 325 xi |
samokin-
The big '!' lights come on along with the brake lights while im driving. It goes on and off whenever i hit a bump or sometimes just while im cruising. Im thinking its something to do with the wires. Bear in mind that I've only own the car for five months, still dont know much about it. I dont know what idiot' light that you are refering to on the dash board but I sure hope that you dont have one on your dash board. -just tryin to fix this annoying prob. sasaki |
Sasaki,
An "idiot light" is any light on the dash, other than a guage that gives you an actual measurement (Like the oil level guage), that usually comes on to tell you about a problem *after* it has happened. It sounds to me like you have a faulty contact on your emergency brake switch. It should be located somewhere in your cover boot. (I'm assuming you have checked break fluid level and found it to be normal.) Just a thought... I'm assuming that your brake pedal feels normal during brake application and that your car stops normally.
Author of "101 Projects"
Could be:
- Fluid - Ebrake - Pads (I think these cars have sensors). It's tough when this one light does so much, I wish there were more detail on these 'idiot lights.' -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Member
Hello
If it is the central warning light and you have to quit it with the switch then just visit any local Porsche shop and have them look for your brake system ASAP. Better now then later. http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=4&t=002294 http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=4&t=000151 http://forums.rennlist.com/cgi-bin/rennforums/ultimatebb.cgi?ubb=get_topic&f=4&t=000133 Grüsse |
Brake fluid level is checked and it was filled to the top. I took a peek at it, but Im not sure how to check for the worns in the pads. I guess its time to take it to the shop to get it checked out. I was hoping that i could fix the problem myself. probably a faulty in the ebrake wires.
-big thanks to everyone that replied. >>>sasaki |
Which light did you say comes on intermittently?
There are actually three functional lights and one general warning light "!". Brake Pressure/Fluid Level = "BRAKE" Problems: Brake Fluid Pressure Differential in Hyd. Circuit Brake Pressure Switch Failure Low fluid in Brake Reservoir Low Fluid Switch (Switch State: Normally Closed with full fluid) Sensor circuit for Brake Reservoir open 2. Brake Wear = “symbol looks like a brake drum and shoes?” Circuit State: Normally Closed Loop Problems: Brake sensor bridge wire worn through or broken Brake sensor wire harness open condition 3. Parking Brake = "PARKING BRAKE" Switch State: Normally open Problems: Parking Brake Switch adjustment
Keith Drive Hard and Fast 1991 Carrera 2 Targa 1972 911T Coupe 1971 914 |
