Roof stuck URGENT HELP NEEDED
I have A 964 convert & the roof was working perfectly untill yesterday when I opened it up after a drive I went to put it back up & it went to the windscreen & just stopped it wont even go back I hear A clicking noise coming from the module when & press the switch to activate the roof so I;ve taken ther module of & I can see it trying to work, how can A person tell if the modules faulty?
Old 11-29-2015, 03:49 PM
yel911's Avatar
If I understand you correctly, the motors on the left and right do not latch to the windshield frame?
If this is the case, one of the motors has a broken brass gear. There are many threads on replacing the gear.
74' 911 w/3.2L (sold)
95' 993 C2 Triple Blk Cab.
02 Honda Superhawk (sold)
2018 Toyota Tundra Limited
2004 CRF250X
Old 11-30-2015, 04:20 PM
nickd's Avatar
If it went to the windscreen and stopped, then the microswitches above the windshield may not be getting triggered by the front of the top. Possibly one of the two cables that push into the motors (located behind the rear seats) has pulled out of the gear, keeping the top from closing far enough to trigger the switches.
The fix requires a new cable, or shortening the sheath of the current cable. You also need to re-align the cables and likely re-index the transmissions. Very common failure. If none of this makes sense, then take it to an aircooled shop that has seen a cabrio before.
Alternatively, just convert the top into manual mode. Mine all works, but manual mode is just as easy and it's much safer to the components.
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 12-01-2015, 10:49 AM
Hello sorry to hear that, i'm gonna send you a PM with my phone number and try to walk you though some things
Helio
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 12-01-2015, 03:16 PM
