Repairing ground/earth points
Hi,
I'm staring at at least 2 ground points in my empty engine bay. They're rusted to ... I've tried putting a spanner on them but the nut is now totally rounded. If I put much more effort/strength into their removal they're likely to disintegrate entirely. Any/all suggestions welcome, please. TIA John Last edited by johnhedge; 02-04-2016 at 03:43 PM.. Reason: Trying to add photo |
Hello, have you tried a dremel/die grinder to remove the fastener? Including a picture might help. Good luck.
Funnily enough I bought a Dremel a few days ago. I haven't used it yet.
I tried to upload photos before but I'm a noob. I couldn't find out how to do it! I'll try again. ![]() Easy as! I'm not sure why I couldn't do it before. ![]() |
My Dremel is only a couple months old. Love that thing.
Your joint seems to be a weld stud and nut. Do you have Vise Grip pliers? I would try that first. You want to make sure you don't hurt the ground stud threads. You only want to replace the nut. |
Quite a conundrum. |
Yes, a conundrum. Have you checked the resistance with a multimeter to ensure it's a bad ground? Maybe leave it alone, if the resistance if ok? Hopefully somebody has run into this problem and can advise further.
Try one of the higher-dollar penetrating oils? Kroil is very well regarded; you can get it from McMaster-Carr.
'90C4 |
Patients and penetrating/rust oil. Sometimes helps to clean out down around the first thread w a pin or the like. If you get a good grip w anything, do small loosening and tighting movements, keep soaking it, even light tapping to gradually break the rust seal.If there is a way do small cut in the side of the nut u can use a hammer/ small chisel or screwdriver to gently " chock" it both ways.
Glad you got it off. Is "Freeze and Release any different from other penetrating oil products?
Terry |
Wurth makes a similiar product which I have used with great results, didnt know loctite got in the game! It freezes the part which allows the oil to penetrate..
I think that maybe I'm dreaming.. |
Thank you!
Terry |
