993 Right Front Wire Harness Question
Greetings Porsche wrenches and technicians.
Question, probably easy for most of you. Some years ago I took this car apart. Unremarkable I can't recall where things were before I got in there. Front bumper cover removed, reinstalling the AC condenser I've five terminals leading out of the fender well; headlamp, fog lamp, turn signal (same as left side). Where do the other two go? Plus I've a sensor. It likely mounts on the bumper bracket, but I need info on a precise location. What is the color code of the wires to the sensor terminal? Photos attached. Thnx. PH ![]() ![]()
zffnhsn |
