Part Application Help
I need help to indentify the application for PN 964 423 077 02
I need to find out what year and model this clutch pedal fits. Thanks Bill |
After much searching, I finally have an answer for you...
The standard clutch pedal, 964 423 067 02, has been dropped and I assume it is NLA. That pedal is the one originally fitted to '89s, '90s, and '91s. The replacement part number specified to be used instead is 964 423 077 02 - if I remember correctly, you have a '91, so 964 423 077 02 will work for you. (if you have access to the PET, access illustration 702-00, the pedal cluster, for a '91, and double-click on part number 2 - that'll bring up the information) Hope this helps! SmileWavy edit: for clarity, and to add that I'm going to cross-post this to your Rennlist thread. |
| All times are GMT -8. The time now is 09:36 AM. |
