Installing the air duct for engine cooling fan 1995 911 Carerra 2
I'm looking for instructions on removing the old air duct and installing the new one.
Old 05-22-2016, 07:11 AM
stevepaa's Avatar
AFAIK just remove those three 10 MM(?)bolts and pull it off.
steve
old rocket inguneer
Old 05-22-2016, 07:19 PM
crg53's Avatar
Yes, remove the three 6mm screws, (10mm socket size) and you should be good to go.
Old 05-23-2016, 07:33 AM
It does also help to remove the 13mm hex head bolt that holds the a/c line bracket to the a/c compressor, just to give you some extra room. If you have trouble getting it all lined back up it is really easy to remove the blower, just remove the 2 10mm bolts on the left side of the blower, and disconnect the electrical connector from the solenoid at the bottom left of your picture, then disconnect the vacuum line at the bottom of that solenoid, and the blower will come right out.
Old 06-06-2016, 04:39 PM
