-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Pelican Parts Project 993 Technical Articles Comprehensive List (http://forums.pelicanparts.com/porsche-964-993-technical-forum/939156-pelican-parts-project-993-technical-articles-comprehensive-list.html)
Dmitry at Pelican Parts 12-13-2016 02:01 PM
Hello Fellow Pelicans SmileWavy
We have a 993 in our garage right now that is being torn down with new DIY, tech articles being created for that model. I have put together a comprehensive list for you here that will continue to be added to as new articles are published.
If you have any questions pertaining to the articles' instructions or if additional info is needed to clarify, please post a Comment just below the article and we will get back to you.
Porsche 993 Project: AC Compressor Belt Replacement
Porsche 993 Project: DME Relay Troubleshooting
Porsche 993 Project: Fuel Pressure Regulator Replacement
Porsche 993 Project: Rear Deck Lid Shock Replacement
Porsche 993 Project: Non-Varioram Blower Motor Assembly Replacement
Porsche 993 Project: Oil Filler Bellows Replacement
Porsche 993 Project: Engine Air Filter Replacement
Porsche 993 Project: Non-Varioram MAF Sensor Replacement
Porsche 993 Project: Non-Varioram Airbox Removal
Porsche 993 Project: Non-Variram Air Intake Temperature Sensor Replacement
Porsche 993 Project: Non-Varioram Idle Stabilization Valve Replacement
Porsche 993 Project: Airbox Removal
Porsche 993 Project: Varioram Air Intake Temperature Sensor Replacement
Porsche 993 Project: Vacuum Distrubution Fitting Replacement
Porsche 993 Project: Blower Duct Temperature Sensor Replacement
Porsche 993 Project: Varioram Blower Motor Assembly Replacement
Porsche 993 Project: Understanding Your Oil System and Gauges
Porsche 993 Project: Idle Stabilization Valve Varioram Replacement
Porsche 993 Project: Varioram MAF Sensor Replacement
Porsche 993 Project: Shroud Air Diverter Replacement
Porsche 993 Project: Fuel Pump Testing and Replacement
Porsche 993 Project: Under Engine Tray Removal
Porsche 993 Project: Rear Bumper Shock and Reinforcement Replacement
Porsche 993 Project: Fuel Pump Check Valve Replacement
Porsche 993 Project: Rear Reflector Replacement
Porsche 993 Project: Distributor Removal and Belt Replacement
Porsche 993 Project: Power Steering Fluid Flush and Bleed
Porsche 993 Project: Rear Tail Light Bulb and Assembly Replacement
Porsche 993 Project: Rear Bumper Cover Replacement
Porsche 993 Project: Knock Sensor Replacment
Porsche 993 Project: Fuel Injector Replacement
Porsche 993 Project: Setting Your Engine At TDC
Porsche 993 Project: Cooling Fan Belt Replacement
Porsche 993 Project: Alternator Replacement
Porsche 993 Project: Voltage Regulator Replacement
Porsche 993 Project: Cooling Fan Bearing Replacement
Porsche 993 Project: Throttle Positioning Sensor Replacement
Porsche 993 Project: Distributor and Rotor Replacement
Porsche 993 Project: Fuel Delivery Tests
Porsche 993 Project: Fuel Filter Replacement
Porsche 993 Project: Cooling Belt Sensor Replacement
Porsche 993 Project: Alternator Belt Replacement
Porsche 993 Project: Power Steering Reservoir Replacement
Porsche 993 Project: Power Steering Hose Replacement
Dmitry at Pelican Parts 02-06-2017 02:10 PM
If anyone is looking for additional DIY tech articles on the 964/993 platform, click the below link -
Porsche 964 & 993 Technical Articles (1989-1998)
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
