Loctite 574 or.....?
I'm replacing a couple oil lines and was suggested by Andial to use Loctite 574 on the fitting and oil line. I can't find this anywhere! Do you guys recommend anything else? Somebody said to use teflon (plumbers tape). I couldn't imagine using teflon on a P! Any suggestions or opinions are greatly appreciated!
Thanks,
John 1997 993 2012 991 Last edited by schubee; 01-28-2003 at 01:58 PM.. |
Joh, I couldn't imainge using Loctite on oil lines, but then again I'm not Andail whose employees have probably forgotten more about P-cars than I know.
Wayne recommended teflone tape for oil sending units, and that is what I am going with. Here is a link about case sealants that may help. Let us know what you decide.
Loctite comes in *many* different flavours, and if Andial recommend it, I'd be inclined to use it.
www.mcmaster.com will sell you just about anything like this you could ever possibly want.
'90 C2 Coupe - 104k miles |
I found some Loctite 574 at Mesa late yesterday afternoon. I heard it's more of a sealant and was also recommended by other P mechanics. I went ahead and used it.
Paul, congrats on your three six. I'll need to stop by and check it out. I decided to go with the GHL exhaust and I should have it in by tonight if all goes well. The car looks different now with the new wheels and lowering. Cya...
John 1997 993 2012 991 |
Hi Guys,
Looks like Im just a little too late here, but for anyone else in need of this product. We have it and another item that needs to be added to the site. Hope this helps, Don Loctite 574 (50 ml), Part # PEL-10-9526-010 $15.70
Don Haney don@pelicanparts.com Pelican Parts 888-280-7799 Ext 305 1991 C2 Tip - Sold |
Hi Guys,
