-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   993 not start (http://forums.pelicanparts.com/porsche-964-993-technical-forum/945809-993-not-start.html)
daiergas 02-13-2017 05:21 AM
993 not start
hello, i've 993 c2 1994 that no start
the battery has run down four or five times and I reloaded, I have now changed but does not start
immobilyzer is ok,
dme relay ok but don't have ground on 85
thank you
Dmitry at Pelican Parts 02-13-2017 10:15 AM
Have you checked your alternator regulator? If your battery isn't holding a charge, this could be the issue.
-Dmitry
daiergas 02-14-2017 05:57 AM
yes is ok,but don't have ground out of pin 36 on the ECU
Bill Verburg 02-22-2017 06:46 AM
'94 993 uses Motronic 2.10.1 which wants a ground at pin 36
I'd start by finding the break in the wire that prevent that.
The most common issues are related to the DME relay or the immobilizer
