Inspecting Engine Internals - without splitting the case
How much of the engine internals can be inspected without splitting the case? What can be checked to determine if it is within spec?
I don't want to start my 964 engine without checking as much as I can. Thanks for any help. |
Did you just buy the car? Do you mean starting the car, or starting a rebuild Need more specifics.
Engine is on an engine stand.
I have found an issue with the exhaust valves, what can be checked if I remove the P and C's? |
Thanks, can you measure the crank?
You can't measure the crank without splitting the case. How many miles? The bottom end is pretty robust.
Low miles - former race motor. I have it on an engine stand and need to have some cylinder head work completed, or replaced.
Thanks for the input. |
