AHudson's Avatar
What is this wire under my seat?
I was removing my seats and carpet due to a rather intense smoke smell in my newly-acquired 993. After unclipping the main power seat plug, I removed the seat to see this unwelcome sight.
The now cut wires - a black and a brown - had gotten wrapped in the spiral mechanism that moves the seat fore and aft. (I get to extract that later today as the mechanism worked but was labored.) These wires are smaller than the other power wires.
So what the heck does this go to? Or what does it operate? I don't recall anything not working, but something is definitely no operating as Porsche intended, whatever it may be. Any insights?
Porsche M491 Coupe '85
Porsche 997 GTS '12
Porsche 911 SC, '82
Porsche 914-6, '70
Audi S4 Avant V8 manual, '05
Old 11-29-2024, 05:47 AM
Under which seat - passenger or driver (l/h or r/h)?
Also, is there an unconnected and loose connector/pin housing around there somewhere, like the one in the image?
https://i.ebayimg.com/images/g/~64AAOSw6uNmTf4Z/s-l1600.webp
___________________
Current:
964 C4 - Light RS additions and modifications
968 Sport - M030 suspension with adj Koni Setup
Mk 5 Golf GTi - As good as it gets
Old 11-30-2024, 02:23 AM
AHudson's Avatar
Thanks so much for your reply. I ended up finding the other end all chewed up in the seat mechanism. It is for the seat belt warning buzzer/light. I re connected the wires and it all goes nicely back together.
The one you showed is indeed the main power harness connnector, a stout little affair that is difficult to separate with one hand as you attempt to hold the heavy seat with the other!
Thank you again for the reply.
Porsche 997 GTS '12
Porsche 911 SC, '82
Porsche 914-6, '70
Old 12-01-2024, 03:06 PM
Glad you're all sorted. Yup, there are plenty of connectors, controllers, relays etc hidden under both seats (throw in nightmare custom audio installations and associated amateur cabling too).
___________________
Current:
Old 12-02-2024, 12:30 AM
