Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
Now in 993 land ...
aigel's Avatar
0W-40 or 15W-50 Mobil 1?
I have used Mobil1 15W-50 in the past. Reading on recent threads, looks like people are running 0W-40 and that shows on the Mobil1 as Porsche recommended.
I like thicker oil for the few times I may run the car hard, track day, canyon run etc. I don't think it ever gets cold enough here to warrant 0W but I am definitely not an expert ...
What do you run in your 993 and what do you recommend!?
I like Mobil1 for easy availability and price ... so not interested in the other brands currently ... oil change coming up! Getting ready for Laguna!
Thanks,
George
81 SC (sold)
Old 05-18-2017, 10:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Bill Verburg's Avatar
Thanks,
George
Besides the weight be concerned about the additive package used in a given oil.
When 993 were new the oil spec was SH, the oil issue these days is that the EPA wants oe emissions equipment to last a long time, to that end Zinc & Phoshorous content ave been reduced in many brands/types of oil. The issue is that the ZDDP(Zinc & Phosphorous) are necessary to protect flat tappet cams as used in 993. The first wave of cam failures was reported after the SL spec(1000 ppm ZDDP) came out in 2004, The oils to be avoided have a starburst API symbol on the can, the older API donut may or may no have reduced ZDDP.
M1 0w-40 has 1000/1100 ppm P/Zn marginal as it's right around the 1000 level where issues first arose
M1 15w/50 has 1200/1300 ppm P/Zn right where SH spec was back in the day
I'd prefer a 15w 40 w/ 1200/1300 but this oil is going to be tough to find and very expensive. Until I find it M1 15w-50 is my choice
Bill Verburg
Old 05-18-2017, 10:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Now in 993 land ...
aigel's Avatar
Great info Bill. Thanks for all the detail on the zinc/phosphorous additives. I will stay with the 15W-50 and am glad I haven't jumped on the 0W-40. I have about 25k on my engine since I owned it without issues on this oil.
G
81 SC (sold)
Old 05-18-2017, 06:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
For 993, you should be researching over on rennlist.com forums. But whatever you do, do not post an open-ended "what oil to use question" thread, as the topic has been beaten to death and the snarkey-ness meter will go to 11.
But Bill V., a 993 known knowledgable source in the forums (and a very nice guy in real life) has condensed down the wisdom you seek.
Old 05-19-2017, 04:59 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Now in 993 land ...
aigel's Avatar
I don't have any motivation to post on Rennlist. I always get great input here on Pelican where the culture is a lot more laid back - you can actually ask an oil question!
Bill is the best if it comes to 993 info.
G
81 SC (sold)
Old 05-19-2017, 09:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
KNS KNS is offline
Mention 0W-40 to Steve Weiner and he will practically plead with you not to put it in your 993.
Stick with what you've been using.
Kurt
1984 911 Carrera
Old 05-20-2017, 08:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Now in 993 land ...
aigel's Avatar
Thanks Kurt - indeed. Just received my Walmart Shipment today. And the upside is that I was able to use the leftover 2 quarts from last change!
G
81 SC (sold)
Old 05-20-2017, 11:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
I mixed them 50/50. Mobil techs said that was fine. I don't need 50 weight but like the higher zinc/phosphorous additives. The 0W-40 is cheaper.
__________________________
'58 356A coupe, just a driver
'00 Boxster S
previous Pcars
'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E
Old 05-22-2017, 05:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
You could always throw in some quarts of Mobil 1 V-twin 20W-50 oil at 1600/1750 P/Zn.
I plan on a 50/50 mix with the M1 15W-50 this coming oil change, (my first). Any thoughts on that?
Old 05-25-2017, 10:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
NorCal 96 C2
Half German,
That is what I have done on the last three changes. Seems logical.
Old 05-26-2017, 06:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Nine9six's Avatar
I do the same as well^^^on the 50/50 mix of Mobil V-twin/Mobil1,15-50W, and mentioned it several times on rennlist 993 forum.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 05-26-2017, 09:50 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
"I am the liquor..."
sand_man's Avatar
Joe Gibbs DT50 15W-50 in my daily driver. When I've used the case (9.5-10 quarts for the change and the rest for topping off), I reach for the V-twin 20-50 until the next oil change, with Gibbs.
-jeff
Old 05-31-2017, 01:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Derek911's Avatar
Whether you like rennlist or not, when it comes to 964/993 Pelican cannot compare to the wealth of information on Rennlist. The same people on Pelican are on Rennlist, but Rennlist is where best info is for 964/993. The issue comes when people ask a question that has been thoroughly debated and worked out. The beauty of rennlist is in reading old threads and making a decision based on it versus starting it all over again. With all that said, I'm a VR1 20-50 kind of guy... Based on rennlist and pelican research, not asking a question.
Old 06-04-2017, 12:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Derek911's Avatar
I'm with Steve Weiner on this. 0w-40 makes no sense in our high reving engines. Regardless of how you drive or where you live, you should use high zinc oil closer to racing oil than what new cars use like 0w-40.
Old 06-04-2017, 12:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Our host has a competitive price on Porsche classic motor oil 10w-60- 5 liter can. Agree with the high rev comments above.
John
1989 Carrera 4 Coupe - Guards Red
Old 06-04-2017, 04:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Emo993's Avatar
+1 Sand man, Joe Gibbs DT50, read up on the specs. Just a great oil for the 964/993 air cooled engines. Best, Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Old 06-19-2017, 06:05 AM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Emo993's Avatar
PS, free shipping from LN Engineering.
2007 Cayman S
Old 06-19-2017, 06:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
sand_man's Avatar
Yep...that's where I order. Good pricing too.
-jeff
Old 06-19-2017, 07:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
I was advised by our local Aircooled Guru here in Brisbane Australia to run the 15w-50.
Like you, I also dont see myself needing the cooler temperature aspect.
This was also on a fresh rebuild, so Id rather follow the instructions of my engine builder
Old 06-19-2017, 09:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Are you using Penrith?
Old 06-20-2017, 04:07 AM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
