Oil cooler line
I need to replace the lines that run from the oil cooler to the engine. I am having a hard time finding these. Do you know if the can be remanufactured. I have a 1991 964 Cab.
Old 04-19-2017, 05:14 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Take a look at the link below, we should have oil cooler lines for your 964. Please let us know if you have any questions or give us a call at 888-280-7799 and one of our Porsche part specialists will be happy to assist you.
1991 Porsche 911 Carrera 2 Convertible - Oil Circulation - Page 5
-Dmitry
Old 04-21-2017, 01:07 PM
porsche964guy's Avatar
You got a couple of options:
First: Efern has a used set on this forum Blackbird - He's Shakey!
Second Coline has had them for a long time about $150 each
Coline has been the OE supplier for these as far as I know.
I will be getting a set in the next few months also.
Old 04-21-2017, 04:26 PM
BoxsterGT's Avatar
Porsche Crest
I am able to "Re-Hose" your original for a reasonable cost. The kicker is the shipping. That may be too costly back & forth.
Here is what I am referring to:
I do not have a completed photo but this is available in original Cohline Rubber or Braided Zinc or Braided SS.
Please email me if interested. NO pm's, box is always full.
Len at Autosportengineering dot com
Old 05-11-2017, 02:34 PM
SantaCruzRed's Avatar
Hello Snowgse... not sure where you're located or if you need the entire line (hard & flex) replaced or just the flex. It's pretty common for the junction where the hard line meets the flex line to eventually give out, happened to me (1990 C2) last year. I had Elephant Racing in San Jose, CA replace the flex lines with metal-braided lines at a very reasonable cost. They also have the stock fabric material and the factory RSR material. As a previous poster suggested, it's all a matter of freight. You might consider having them make you a set of replacement lines and find a local hydraulic hose shop to put 'em together for you?
Old 05-28-2017, 11:14 AM
