Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
ANOTHER 964 Aircon Question
So, I just had a specialist replace my compressor, exp valve, drier, pressure switch and evaporator.
Aircon is nice and cold.
However, the volume of air that comes out of the left hand side vents, is no where as strong as the right side blower vents.
What could cause this?
Old 07-14-2017, 10:37 PM
budge96's Avatar
If I had to make a guess I would suggest getting the driver side blower motor exchanged or renewed .
There is a squirrel cage blower behind the interior micro filter that pushes cold condensed air into
the cabin , it's likely failing or on its way out..
Bert
GT2
RS 3.6
RSCS 3.8
R 2.5 Twin Plug
Old 07-15-2017, 10:06 AM
Plus 1 on that, if your talking about a 993 other wise the 964 has no filters.
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 07-15-2017, 10:33 AM
I think another possible culprit is mixing servos weak or inop.
'90C4
Old 07-17-2017, 06:49 PM
I also need my AC redone just like yours, how much did it all cost?
Old 07-20-2017, 09:41 PM
A lot...
I bought all the parts and paid someone to do it for me...
PM me for details should you want them.
Old 07-21-2017, 02:36 AM
Bert
Interestingly, when i questioned my installer, he said that he inspected both blower motors and they were working fine and that the brushes were also in OK condition and did not require replacement.
I have played with the airflow a bit; it appears as if the 2 outside vents, closest to the doors are blowing at the same amount of force.
However, the 2 centre vents, even though they are right next to each other, blow at very different force...
If it blows nice and cold all through the summer and beyond, then I will be happy (ish).
Old 07-21-2017, 02:39 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
