Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
Porsche Crest Manual locking?
I removed and then installed the door handle, and while I'm currently missing the electric switch that activates the central locking, I think the doors should still be able to lock and unlock mechanically, correct? They don't, so I guess I've not put the door locks together correctly? (1990 911 C2 targa).
Old 07-30-2017, 07:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Yes on my 1993.
When I disconnect the battery, I can still lock the doors mechanically with the key.
1993 964 C2 still makes me smile
1996 318ti (269k miles)
2011 Silverado for hauling (32k miles)
Old 07-31-2017, 06:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
I think you can only unlock the door manually on a 1990, you'll need the micro-switch to lock them
Old 07-31-2017, 11:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
My mistake.
I cannot lock and unlock mechanically with the battery disconnected.
It must have been possible on my 1996 BMW.
Old 08-01-2017, 10:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Cobalt's Avatar
I don't recall the exact year but the early 964's can only be unlocked with a key. They made a change to the locking mechanism I believe in 1991 when they changed the rear lid latch as well. They added an extra tang or extension to the locking mechanism so that it can be both locked and unlocked with the key. They also at this time added pull cables to the front and rear latches to release them in case the main release cables break.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 08-01-2017, 04:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
