Author of "101 Projects"
Wayne 962's Avatar
Porsche 993 Project: Power Steering Fluid Flush and Bleed
Anyone got any questions on the Project: Power Steering Fluid Flush and Bleed for your Porsche 993?
Here's a back link to the original article: Pelican Technical Article: Power Steering Fluid Flush and Bleed
-Wayne
Old 12-01-2016, 04:45 PM
Turboman's Avatar
Send a message via Skype™ to Turboman
My 964 Carrera 4 1991, power steering needs a flush and bleed. I read the article, nice and complete, the question.
1- Can I use Pentosil in my 964?
2- It is really necessary to change the oil reservoir.
Francisco
Old 08-24-2017, 07:09 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello Francisco - it is not necessary to change the reservoir unless there is debris in the system (such as from a failed pump or such). The current OEM version of Fluid is Pentosin CHF 202.
Old 08-24-2017, 12:12 PM
Turboman's Avatar
Thanks Dmitry. Have a nice day.
Old 08-24-2017, 11:10 PM
Turboman's Avatar
Dmitry, how many liters of Pentosin, I need to correct flush the system? Thanks
Old 08-25-2017, 08:33 AM
Turboman, I believe the whole system holds about 1 litre. Draining/removing the fluid container will only remove part of this. To basically replace all the old fluid with the gradual replacement drain method I would say you need about 2 litres. What does the existing fluid look like?
Old 08-26-2017, 05:05 AM
Turboman's Avatar
Paperboy, thanks.. The actual fluid looks dark, but the system have no leaks or damp areas.
I want to change the fluid using Pentosin, cleaning at the same time the fluid container.
Have a nice week end, thanks for the info.
Old 08-26-2017, 09:02 AM
