Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
nickd's Avatar
964 vs 993 caster
I've been wondering about this one for a while, caster angle specs are:
964 4*25'
993 5*20'
Where does the 993 find the extra degree? Are the strut top mount holes in the tower moved further aft? Or is the difference down at the control arm? I believe that the rubber strut top mount is the same between models? Is it a product of geometry changes in the front track width due to the differences in the longitudinals?
Many 964s struggle to reach the factory caster spec, is there room to go beyond 5*20' in the 993?
Side note- I swapped my 964 steering rack to a 993 rack and the steering effort became noticeably lighter. I wonder if the 993 caster increase was partly, or wholly, to add weight to the steering feel on the 993 with the different rack.
Old 09-07-2017, 06:32 AM
The only difference between the 964 & 993 control arms is that the pressed-in balljoint mounting stud is larger on the 993 arm.
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2001 Toyota 4Runner, Dorado Gold, 410,XXX 1-owner miles
Old 09-23-2017, 04:41 PM
budge96's Avatar
I have seen evidence from BVerburg that the lower longitudinals on the 993 have added strength
and negligible width where the mounts for the Aarms bolt up.
This added width I believe is where the 993 gains in wheel span ...Bert
GT2
RS 3.6
RSCS 3.8
R 2.5 Twin Plug
Old 09-23-2017, 05:00 PM
Cobalt's Avatar
The 993 longitudinal push the front end out 12.5mm per side
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 09-23-2017, 05:23 PM
