Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
964 oil temperature
Dear All,
i have a 964 C4 1991, the oil temperature in race mode, reaches 234 f, and even in traffic is always getting higher so i have to stop to cool down the engine,
the fan is working well, the oil is circulating correctly!!!
i tried to put the fan on high speed always still the same. i am using Mobil 20-50 oil level is ok,
what do you think the problem is?!
Old 09-15-2017, 02:31 AM
Did you try tapping on the oil gauge when it spikes ? My gauge will get stuck at max every once and a while. I can't imagine your car getting that hot with 20w-50 and oil circulating well.
Old 09-15-2017, 02:21 PM
Were do you live, that is what is your ambient temperaturen? If you are cruising at 60 mph in top gear, what temp do you have? Do you have the engine undertray on the car?
Old 09-16-2017, 04:54 AM
I did the same thing, tapped the glass, I did replace the gauge, Problem solved
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 09-18-2017, 12:14 PM
I had to replace my oil temp gauge as well on my 1993.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 09-19-2017, 05:45 AM
