Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
1991 964 porschre
964 HOW TO OPEN FRONT HOOD CABLE IS NOT BROKEN,Anyone please.Thank Mark
Old 09-25-2017, 12:07 PM
porsche964guy's Avatar
What do you mean? The lever next to your left leg mounted in the lower side of the door opening is not working? Or do you mean the safety catch located on the front inside of the hood?
Old 09-25-2017, 01:39 PM
Hi bye the way thanks , the cable is not broken on the inside .IS there a emergency, latch , on my car ,many people say no , do u know for sure , iwas told if u take off driver side tire an half of the fender well ,there is a cable , is this true battery is dead I need to get this beast running
Old 09-25-2017, 03:01 PM
When you pull on the release lever inside the car the hood should open about an inch. This allows access to the hood safety release in the front center under the hood. Place your hand under and push up the latch while pushing down on the top of hood slightly. It should open.
Old 09-26-2017, 09:23 PM
Cobalt's Avatar
The lid sometimes sticks closed if it hasn't been opened for a long time. Have someone try to pull up on the lid when you pull on the release mechanism. Using a plastic pry bar will also help. If not there is a release cable inside the front left wheel well. You need to remove the wheel liner to access it.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 09-27-2017, 05:07 AM
Thanks to every one we pulled on the cable an pryed with a flat piece of wood an it poped , thanks to every one that replyed
Old 09-27-2017, 02:48 PM
