Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
993 sputters when cornering hard
The car idle is good. So is accelerating. But when I corner fast and sharp it almost dies. Is this a sign of a failing corner accelerator ? Thanks in advance for input.
Old 09-27-2017, 06:41 AM
Administrator
Dmitry at Pelican Parts's Avatar
I'm not sure if this relates, but I remember reading about an issue similar on a BMW and the fault turned out to be something with the injector harness being chaffed by the steering linkage somewhere under the car. It only happened when turning corners.
Old 09-27-2017, 11:40 AM
Thanks Dmitry. I'll give it a look.
Old 09-27-2017, 12:41 PM
On a 911, the steering is in the front and the engine is in the back...
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2001 Toyota 4Runner, Dorado Gold, 407,XXX 1-owner miles
Old 09-27-2017, 01:36 PM
Andreas
Guess it would be hard to tangle those two up on a Porsche thanks
Old 09-27-2017, 02:45 PM
What is a "corner accelerator"?
How much fuel is in the tank? Sounds like it is starving?
Old 09-28-2017, 01:19 AM
Its going to be tough to diagnose.
You will need to find out if it's spark or fuel causing the momentary sputter when cornering hard.
Do you have CEL on?
Do you have a diagnostic tool and a passenger to monitor when cornering?
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 09-28-2017, 02:25 AM
Do you have CEL on?
No cel. No diagnostic tool. ( wish I had a Bosch hammer but dang they're $$ ) full tank of 91 non ethanol octane. New plugs/cap/rotors. Fuel filter is about 1k old. The wife drives this and I'm hoping it was just in need of a Italian tune up. I haven't pushed it around a corner in a couple of days. Just odd that it's not happening whilst driving straight
Old 09-28-2017, 06:59 AM
I guess lateral acceleration sensor is the correct term? I've not heard much about these going bad ? Just sounds like something that could give a bit of trouble ?
Old 09-28-2017, 07:25 AM
We had a 964 keep cutting out on a road trip. It turned out to be a loose connection underneath the front fuse/relay box. I suspect something is moving on corners, cutting out a connection. Is it both left and right corners?
Old 09-29-2017, 05:19 PM
Thanks for your response. It cuts out turning right
Old 09-29-2017, 05:54 PM
Don Plumley's Avatar
Try reseating or replacing the DME relay.
Don Plumley
96 993 Track Hippo | Spinning Hippo Racing
Old 10-08-2017, 12:53 PM
I didn't think of that. I have a spare. I'll give it a try. Thanks
Old 10-09-2017, 06:59 AM
Nine9six's Avatar
Andreas
I could be wrong and often I am... But I believe the thought of a chafed injector wire could still be valid, regardless of what it's rubbing on.
I just addressed such an issue on a friend's 05 Cadillac STS, where an Indy had told him it was a bad computer.
The OBDII code was a bad fuel injector circuit, #5 cylinder...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 10-09-2017, 04:25 PM
Thatís what we tried with the 964. It worked immediately after changing the relay so we figured it was the relay. However, it was changing the relay that moved the loose wire under the replay board and let it work until car movement stopped it again. Good luck finding the problem.
Old 10-10-2017, 02:07 AM
