Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
964 mystery noise/rattle
Trying to get my new-to-me 964 sorted out, and I'm struggling to locate a mystery rattle. Driving over lane dividers or expansion joints produces a metallic rattle that sounds very much like a loose washer and nut at the end of a metallic rod or bracket. I've isolated the sound to an area around the passenger back seat. I've pulled the passenger front seat to clear out the area, but don't know where to go from here. It sounds like the epicenter is the rear passenger seat cushion, but that's obviously not it. If the rear seats were held in place by 4 bolts and nuts and all 4 were loose,and ratting, that's what this sounds like.
Any thoughts on where to dig?
Old 10-01-2017, 12:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
NorCal 96 C2
Right about where the starter is. Have you checked above the transmission for cables hitting the floor metal?
Old 10-03-2017, 05:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Derek911's Avatar
Catalytic converter or exhaust. The noise is probably outside under the car.
Old 10-06-2017, 06:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
I had a similar sound on the passenger side. Ended up being a lost bolt from the muffler holding bracket
Old 10-06-2017, 09:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
mbintx---mistery noise.
Yeah usually underneath. Check the heat shield by the Cat converter. If those nuts are loose they make noise that will drive you nuts especially when downshifting.
Old 10-11-2017, 02:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Noise is definitely not coming from under/outside the car.
Old 10-26-2017, 08:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Does it change if you drop/raise the rear seat backs ?
On a coupe there’s not much mechanical back there apart from the hinges and latches for the seat backs .
Old 10-26-2017, 09:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
