Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
Can you still find new MM Cup 1 wheels?
Hi,
I looked around and cannot find a source that sells Mille Miglia Cup 1 replica wheels in the US? It is a thing of the past?
Thanks!
Old 10-16-2017, 08:35 PM
nickd's Avatar
You can buy them through fvd usa. There are a few different versions that mm has produced over the years. The rim edge has a slight bevel on some of their versions and not on others. Check the fvd photos closely if you’re trying to match one that you already have.
Old 10-18-2017, 04:43 AM
Thanks Nick, that's what I was looking for. They don't seem to have the original 7/8 size for the narrow 964 though.
Old 10-18-2017, 03:09 PM
nickd's Avatar
The 7.5” et52 and 9” et47 set is a great combo for narrow body 964. The usual tire setup is 225/45/17 front and 255/40/17 rear. You can get a little rub in the front on full lock, but a 3-5mm spacer will fix that. The rears can be left alone or spaced out by 15mm+, depending on camber, if you like. Be aware that spacers bigger than 6mm require longer lugs.
I wish these wheels were lighter, but they’re not much worse than the factory cup 1 wheels and they’re lighter than the 17” ruf varieties.
Old 10-18-2017, 04:35 PM
911 jared
911 jared's Avatar
Send a message via AIM to 911 jared
Im running the 17x7.5 and 17x9 mm cup1 reps with 225/45 and 255/40 tires. The car is lowered and doesnt rub one bit.
Great wheel. I couldnt afford the real 17x7/17x9 porsche set. Id rather spend it on BBS wheels.
Good luck on hunting. Im they pop up used once in awhile in the classifed section.
95' porsche 993 carrera2
89' porsche 964 carrera4
87' porsche 911 carrera (sold)
05' honda s2000
Old 10-19-2017, 10:33 AM
911 jared
911 jared's Avatar
here is a used set i found in the classified section.
Some Porsche wheels in North Carolina for sale. Cup 1's,Techarts and 997.2 Turbo
05' honda s2000
Old 10-19-2017, 10:42 AM
nickd's Avatar
Check the inner wheel well behind the strut. I would be amazed if you're not rubbing. But maybe those front tires run narrow. Porsche issued a service bulletin for 17" wheels which requires a thicker steering rack stop to reduce the steering angle. Though you don't really need the thicker stops if you use a 5mm spacer.
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 10-19-2017, 02:04 PM
hda hda is offline
I have a set I plan to install soon.
Jared - love your car!
Old 10-20-2017, 12:01 PM
911 jared
911 jared's Avatar
HDA-thank you!!!
05' honda s2000
Old 10-24-2017, 05:37 PM
I ended up going for a set of used OEM cups. I paid $2000 and they are in good conditions, that might be a useful reference point for someone looking.
Old 11-23-2017, 08:20 AM
Location: Outside of NYC, inside it during the work week
Those look like 16"...am I wrong...or is the car on normal height?
Old 12-04-2017, 01:26 PM
They are 17" and the car is at OEM US height (which is normal but ... well, way too high).
Old 12-05-2017, 05:20 AM
7s and 8s? or 7s and 9s? Just curious.
Old 12-06-2017, 10:33 AM
7s and 8s
Old 12-06-2017, 04:52 PM
Originally Posted by 911 jared View Post
Are my eyes playing tricks on me or did you remove the center bar in the front bumper grill? I've never seen that before and I really like it.
-TJ
C2 Coupe
Old 12-23-2017, 11:35 AM
Good eye, that does look really good/clean.
Old 12-23-2017, 12:12 PM
911 jared
911 jared's Avatar
TJ- yes the center bar is deleted. Kinda copied Magnus Walker's taste on his 964.
05' honda s2000
Old 01-01-2018, 11:40 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
