Angry 1991 964 porsches
964 Porsche .... air scoop is not going up , ran it to 100mph, no luck any input .thanks
Old 10-20-2017, 01:58 PM
budge96's Avatar
could be a host of things but most likely fuse related , if that doesn't do it check relay and or sending unit under the dash center behind floor vent .
Also possible to be the transmission or cable under rear lid ,if it moves freely when manually lifted
thats your best bet..
Bert
GT2
RS 3.6
RSCS 3.8
R 2.5 Twin Plug
Old 10-20-2017, 02:53 PM
Check the linkage of the spoiler, I had a bolt backing out on mine that was hanging up the mechanism and causing mine to stick.
Ralph W
Old 10-20-2017, 03:46 PM
Does it lift when you turn the manual button ?
If not , It’s easy enough to check the mechanical by simply removing the cable from the motor under the engine cover , wipe any grease of the square cable end , then turn the cable with your fingers whilst gently giving a little assistance by holding the weight of the spoiler in your other hand .
You should be able to easily go through the entire range of movement both ways by hand .
If all good , the electrics are pretty simple .
Iirc , just 12v ffrom switch to motor , and a limit switch each for fully open and fully closed .
I don’t have my 964 in front of me right now , but it’s really easy to check with a multi-meter from the switches or the round plug that disconnects the rear lid harness in the engine bay .
Old 10-20-2017, 06:46 PM
Thanks for all the great input
Old 10-22-2017, 09:33 AM
Did you fix it ?
Old 10-27-2017, 10:01 PM
Just thinking ... (drunk)
You do know you can’t see it from the rear-view don’t you ?
Not wanting to state the obvious , but are you sure it’s not working ?
Over the years plenty thought it wasn’t , but it was and they just couldn’t see it whilst driving .
(Well , you can , but at “spoiler-up” speeds it’s better to stay in your seat and look at the road)
Old 10-27-2017, 10:05 PM
how true I looked today an could not see it , hit 100 many times today, Wanted to stay in my seat , thanks for input, call uber
Old 10-29-2017, 12:31 PM
