-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Right Side Timing Chain Cover Removal (http://forums.pelicanparts.com/porsche-964-993-technical-forum/974698-right-side-timing-chain-cover-removal.html)
jamesjedi 10-21-2017 07:05 AM
Hoping for some guidance.
Do I need to remove the crank pulley to remove the timing chain cover? I have loosened the AC bracket and I still do not have enough room.
What about removing the studs for the cover?
jamesjedi 10-23-2017 11:14 AM
I can do it with removing the studs, however I am getting the tool to replace my crank pulley.
wesleyc 10-24-2017 08:05 AM
I removed my studs to slip the cover off. If or when I take crank off Iíll alter / cut away the binding portion of the AC bracket.
jamesjedi 10-24-2017 12:48 PM
I was thinking of cutting it as well. Also, the engine carrier can be backdated to use 3.0/3.2 parts if your engine is in an earlier car.
I ended it buying the crank pulley tool. Awaiting its arrival in the mail.
john walker's workshop 11-09-2017 12:13 PM
When it's off, cut away the flanges on the aluminum piece that traps it behind the crank pulley. Then you don't have to remove the pulley to get it off, or pull studs, especially the upper right one that you can't get anything on to turn it.
jamesjedi 11-11-2017 11:21 AM
I should have done that. I now have the tool - I am going to remove the pulley anyways and install an OEM pulley.
Thanks for the help - I really appreciate it!
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
