Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
Help, I broke the top
Hi friends,
I am quite sad and really unlucky, my convertible top broke after a mere 5 hours of ownership. I picked it up, drove it back home super happy and while operating the top to close it, I did not notice that the left side was a bit stuck. In a split second, I heard a big snap and here's the result:
I was so happy
How bad is it? Is that a piece that is part of top replacements? (like a GAHH top?)
Old 10-26-2017, 10:44 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Quite common .
You I have to make sure the car is on level ground before operating the hood , and on buy9ng a new car I’d check the motors , gearboxes , switches , wire-cables , and visually inspect the cast parts before operating the roof .
There’s too much torque to cause issues if everything isn’t perfect .
Edit , as I was thinking about your misfortune earlier whilst going for beer .
When I say level ground , I mean left to right .
Parked on a slight incline such as a driveway is ok , but parked on a level street with one side of the car up on a kerb is not .
Even if everything is working and the cables are turning freely and have anough length that they won’t pop-out of the gearboxes etc , if you’re parked with one side of the car higher than the other the wieght of the roof and gravity pulls it to one side and you get the dreaded “crack” .
Not much help for you now , but worth remembering in the future .
Also , where did you buy it ?
If it came from a dealer does it have any warranty ?
Old 10-27-2017, 12:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
group911@aol.co's Avatar
Can't tell from the picture which part broke?
Thanks,
Bob
group911@aol.com
Old 10-29-2017, 09:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
I bought it from a very honest private party and it is overall in great shape. It's really a combination of bad luck and not really knowing how it works.
I found a pretty competent specialist here in the bay area and he is looking at it now. Most likely it will involve tungsten welding and I am also going for a new top since it tore the old one.
It's just money but let me tell you, it's painful!
@group911, it's the top bow, here's another guy with the same issue: Broken Top Bow on 88 Cabriolet
Old 11-02-2017, 10:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
The top bow is 3 pieces and it's usually the right side that breaks. You can buy each part individually.
Thanks,
Bob
group911@aol.com
Old 11-03-2017, 07:00 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
It's fixed now, I replaced the top completely (headliner and window were not in great shape) and I had the top bow tungsten welded.
These are $3000 that I won't see again and now I need to forget about it all ... and operate my top carefully!
Old 11-23-2017, 09:17 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Looks great, was wondering what you ended up doing.
Ralph W
Old 11-23-2017, 10:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
