964 Brake Disc Warp Issue - Update - Stop Tech Rotors
After a bit of feedback...
When I bought my 964, it had been sitting unused for a while, so I installed new rotors front and rear, and new pads and did a full flush.
After a not long time, I noticed that when coming to a stop, the car would "lurch" slightly... There was no pulsing at the brake pedal.. just the lurching. I also found at low speed when turning sometimes, I had a slight intermittent squeak coming from the rear but as soon as I touched the pedal, the squeak went away.
So I thought perhaps my rear calipers might have had a sticking piston.
I used the opportunity to upgrade to the 993 rear calipers and installed new seals and freshened them up at the same time. I had the rear discs machined again, and away we went. Braking was smooth and quiet.
A few drives later, and the slight lurching and intermittent squeak is back!
Is it possible that a worn wheel bearing could cause this?
Or how about a poor quality rear disc with non-uniform consistency throughout the surface?
Any other suggestions?
Mike
Old 12-12-2017, 01:16 PM
Could also be a bad wheel bearing, which can cause excessive runout
Iron Hill Restorations
Specializing in vintage Porsches
Home of the 914 Umbrella Cover
'91 964 Targa guards red, cashmere
several 914's and loads of parts
Old 12-24-2017, 03:49 PM
I thought this might be the case too... so I had the car inspected by a porsche specialist and they confirmed all bearings were good.
Sine then I have now fitted a new pair of stop tech discs and pads to the rear.. and will do some miles to see if the issue returns.
Old 12-24-2017, 03:54 PM
Mike, I had this same issue when I bought my car. I suspect the PO may have got sick of chasing the problem too....
I spent lots of money trying to track this down, with the problem returning again soon after each fix.
I finally fixed it by having the rotors machined whilst on the car. 5000kms since and hasn't returned. There was obvious run-out on both front rotors as they were machined (even though they had recently been turned off the car).
Old 01-01-2018, 09:12 PM
Thanks for the reply.. interesting that it was fixed by machining whilst still on the car.. does that suggest that the discs were not mounted properly perhaps?
Still if it fixed your issue, then who's complaining!
I have stop tech rotors front and rear now.. I still need to bleed the system but my initial impression is that braking "bite" has reduced greatly... will see as time goes on.
Old 01-02-2018, 01:43 AM
I tried a new set of rotors/pads and checked mounting and cleaned surfaces.
Also rebuilt calipers in case something strange was happening with uneven piston movement. It took 3 workshops involvement to get it fixed.
A frustrating and expensive beginning to ownership but very happy now.
Old 01-02-2018, 03:37 AM
Check the hub flange with and without rotors total indicated run out with a dial indicator mounted on a magnetic base.
Cheaper than replacing parts.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 01-02-2018, 05:54 AM
Mike, I had a similar problem years ago that turned out to be tires. They looked fine but had taken a "set" from inactivity, and no matter how long I drove the car it still had the symptoms until I got new rubber.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 01-02-2018, 06:51 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Different Porsche but similar problem in the front on my 74. Under hard braking the front would start to vibrate. Definitely from the brake rotors. In my case it was simple "pilot error" when installing the rotors. I didn't properly clean the hubs and the build-up simply caused the rotors to seat improperly. I ended up getting a set of new rotors and all is fine now.
Measuring TIR (run-out) with a dial gauge is the way to go and would have caught this. And it'll nicely differentiate between a bad bearing if run out is already high on the hub flange versus a warped disk.
'74 Targa 3.6 (not stock ) - '01 C4 (almost stock) - '00 ML430 (stock)
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2 - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-02-2018, 02:29 PM
Yep. Got to make sure the hub surface is clean, burr and rust free and hub flange machined surface is not bent.
2018 Suburban Z71
Old 01-03-2018, 08:28 PM
Hi, I thought it might be something like that.. but when I first had the issue, I bought new rotors as I had just bought the car. Then it happened again.. so I got the rotors machined... then it happened again! So I bought complete new rotors and will see how this set goes..
Old 01-05-2018, 03:15 AM
Well, I have installed a new set of Stoptech rotors front and rear.. I went for the slotted ones.
On the rear, I have the stop tech pads. On the front I installed a set of Carbon cooltech pads that I had new in box...
I didn't take photos at the beginning.. but the finish on the rotors front to rear, was different. The rear rotors had that normal machined look with minimal protecting oil on them. I cleaned off with lots brake cleaner before installation. The front rotors had a different appearance, like that had been coated with a grey spray on protectant. I washed these down with brake cleaner too.
After driving a bit and bedding in, the front rotors cleaned up nicely and the surface looks as you would expect for a working disc.
The rear discs, however, are hardly touched.. they still exhibit all of the original machining marks from production and the pads don't appear to be having much contact.
All calipers were bled.
Braking power feels OK..
Dust on the front wheels is a LOT.
Dust on the rear wheels is minor.
Thoughts?
Old 02-06-2018, 01:02 PM
ischmitz's Avatar
Fronts do most of the work - thatís normal
Old 02-06-2018, 01:07 PM
I thought with the weight of the motor in the back, perhaps the bias would be a little different in these cars.. I guess not?
Old 02-06-2018, 01:09 PM
Bill Verburg's Avatar
Thoughts?
possibly even probably not normal, you don't say whatever you have 2 or 4 pot rears but either should be needed in close to what is seen in front. Bia for 2 pot rears is 1.643 & for 4s is 1.889
The rears bled normally both inner and outer? pressure or pedal beed?
Bill Verburg
Old 02-06-2018, 01:18 PM
Hi Bill
I ended up installing 4 pot rears from a 993.. I think that was after some feedback I gained from you in another thread a few months ago... Didn't change the brake bias.
Yes I bled inner and outer and used a pressure bleeder....Pedal feel is firm.
Old 02-06-2018, 01:21 PM
Hi Bill
If the brakes bled normally there probably isn't an issue but to be sure check operation, raise the rear, have someone apply the brake while hand spinning a wheel
Bill Verburg
Old 02-06-2018, 02:16 PM
will do.
Here is my front rotor
And here are my rear rotors
Old 02-06-2018, 04:25 PM
Well, after a few hundred kms, my lurching braking problem has returned... And I am certain it is my right, rear disc.
This is/was a new Stop Tech disc.
It needs more investigating but I have a car on stands in my garage already, so when space is available, I intend to check again: bearing play, flange mount surface, pistons in caliper, tyre trueness.
Old 11-22-2018, 12:01 PM
Raleigh993's Avatar
You need to bed in the brake pads.
https://www.autoanything.com/brakes/how-to-bed-in-brake-pads
Old 11-23-2018, 05:21 PM
