midnight911's Avatar
What is the expected life span of a voltage regulator ? - 95 993
I am suspecting the brush in my alternator is going. Getting intermittent low voltage while driving (battery new and fully charged). What is the typical life expectancy on these things?
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
1989 E30 325i 4dr
2006 Sienna 5dr - the hauler
2010 Cannondale Caffeine II - Lefty
Old 12-12-2017, 11:50 PM
They can last a long time (150K miles plus) in my experience. Still, if you're going to take the time to take the car apart and check it, you might as well just put a new one in. Lots of labor to get to, and the part is not expensive.
Old 12-13-2017, 09:39 AM
Mine lasted 100k. Didn't get any dash warning lights , just checked charge voltage w multimeter. One "brush" was really worn.Contact rings were slightly grooved, but works fine w new regulator. Get a good quality replacement, as per above lots of works to get to one small parts.
Old 12-13-2017, 11:44 AM
thanks guys. I got a little shy of 40K miles over 7 years on it and I know I installed Bosch one last time...the part is relatively inexpensive and I thought it was an easy job so i'd give it a shot. You guys suggesting lots of work is freaking me out a bit tho...
Paperboy, what was the charge voltage reading you saw for you to determine taking the alternator out?
1998 E36 M3 4dr
1989 E30 325i 4dr
Old 12-13-2017, 12:38 PM
It never went above 13,6 volt. Now it varies between 13,5 and 14. ( Bought a cheap volt meter that goes in the lighter socket to keep an eye on things. Also, when I did mine took the chance to repaint the fan and and fan shroud since they will be pretty much off the car. Sometime a quick job tends to swell) . I am sure there are good links on the procedure. This might sound obvious , but if you get an intermittent battery warning light, have you checked the alternator belt/pully?
Old 12-14-2017, 07:01 AM
Also, worth checking/cleaning the earth strap between the startar motor/gearbox and body before you change the regulator/brushes. If there is poor contact this can cause poor charging and also warning lights coming on randomly.
Old 12-14-2017, 11:59 AM
just took the VR out. the job was super easy. not sure who gave me the impression that the job was difficult. I did manage to take the two bolts holding the VR out with the fan in tact, but when i was installing the new VR, i took the fan out for easier working space. Zapping with a cordless impact works wonders for those stuff.
the VR I took out was not Bosch, but was a Kaehler. Digging my old receipt out, i'd only paid $12. I think this was a classic you get what you pay thing.
put everything back together and fired it up. 14.2V.
I do have a cigarette lighter volt meter. So that's what it made me know about low voltage. I'd also checked the belts (mine's a twin belt config, no AC) and no slippage. I never had battery idiot light come on except when rpm dipping low for the LTW. I've experienced the ground strap incident in the past but they are in good shape.
i think you always need to buy Bosch and not to cheap out when it comes to VR.
1998 E36 M3 4dr
1989 E30 325i 4dr
Old 12-17-2017, 02:18 AM
Glad you got it sorted. My rings were possibly a bit more grooved than yours but work fine.
Old 12-18-2017, 07:00 AM
I'm glad too.
Rings...do you know if they are serviceable?
1998 E36 M3 4dr
1989 E30 325i 4dr
Old 12-18-2017, 06:16 PM
I believe new rings are available for Bosch alternators as part of a rebuild. Also believe if they are not to worn they can simply be skimmed. When I changed my regulator I gave them a quick clean with a fine grit paper without taking the alternator apart.Of course simply buying a new or reconditioning one is always easiest. (A very good link on a home refurb is available on this forum)
Old 12-19-2017, 03:57 AM
