After swapping automatic to manual
Hi everyone I am restoring my 964 RWB and swapped to manual gearbox. And now I am trying to start the engine but there is no ignition and the fuel pump won’t start. The engine is cranking . Any idea What’s the problem.
crank/flywheel sensor?
crank/flywheel sensor makes a lot of sense as it is right here by the transmission.
I don't have my schematics easily available, but could there be some communications between the transmission and ECU that need to be figured out? |
Auto and manuals have different ecu’s at least that is how I understand it
Or at least the ecu’s are set up differently jumpers wires ect
Hi all we r trying to find how we can baypass the gear ecu.there is a way baypassing but I will check Fly wheel Sansone
| All times are GMT -8. The time now is 10:11 AM. |
