964 turbo engine stronger than naturally aspirated?
Does the 964 3.6 naturally aspirated and the 964 3.6 turbo use the same connecting rods? Or does the turbo have an upgraded connecting rod that can handle more hp & torque?
Is there anything done to the turbo motor to make it handle the extra power? Or is the same as the naturally aspirated motor.
What is the maximum hp and torque that the stock 964 3.6 turbo motor can handle safely. (Without massive engine internal failure)?
Sent from my iPhone using Tapatalk Pro
Old 01-04-2018, 01:08 PM
budge96's Avatar
The '94 3.6 T engine and the 964 3.6 have the same connecting rods, the turbo compression ratio
however is quite a bit lower than the normally aspirated like 11.1 aspirated and 8.5 .1 turbo .
The 3.6 turbo likely can easily handle 5 or 600 HP with a few mods conservatively.
(Twin plug, larger. Turbos , crank fire ignition )
Bert
GT2
RS 3.6
RSCS 3.8
R 2.5 Twin Plug
Old 01-12-2018, 11:58 PM
