993 Turbo S; GT3
1997 993 Turbo S antenna amplifier
Can anyone tell me or send a picture of where the antenna amplifier is located on my 993 Turbo S? Much appreciation and thanks in advance.
Old 02-05-2018, 06:16 PM
2ndTARGA's Avatar
Should be mounted just underneath the dash top under the far front right (passenger side) corner of the windshield.
It's very hard to get to from under the dash, but you should be able to see it from the frunk. Take off the plastic cover over the A/C unit and shine a good flashlight behind the pass. side trunk hinge strut. Way back and toward the fender you should see a small (approx 1" x 3" x 3") black plastic module bolted on with one nut. If you prop the hood and remove the hinge strut - and have small hands - you can feel and maybe check the connections. One to the windshield is plug in, but the other one - going back to the radio, is either molded into the unit or impossible to remove & check from that position, as I recall.
1996 993 Coupe, Tiptronic, Polar Silver
1977 911S Targa - Sahara Diamond Metallic - Sold
1975 911S Targa - Copper Brown Metallic - Sold
Old 02-06-2018, 07:34 AM
993 Turbo S; GT3
Antenna Amp
Thanks Targa Man!! Can hardly believe that my local Porsche dealer in San Diego couldn't (or wouldn't) tell me the part number or location.
Old 02-06-2018, 08:41 AM
2ndTARGA's Avatar
Happy to help. There's been a lot of threads on this in the Rennlist 993 Forum. Do a search there. Here's one that has some good photos..
https://rennlist.com/forums/993-forum/820685-antenna-amplifier-removal-and-replacement.html
Ron
Old 02-06-2018, 01:20 PM
993 Turbo S; GT3
Ron
Thanks Ron. That should be all I need. Great instructions.
Old 02-06-2018, 04:50 PM
