-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   964 Engine Speed/Ref Sensor (http://forums.pelicanparts.com/porsche-964-993-technical-forum/989294-964-engine-speed-ref-sensor.html)
MichaelS911 03-02-2018 09:56 AM
Hi All
I have purchased a new Bosch sensor for my 964 and the terminal on the sensor is different to the original one. I bought it about 4 months ago and have only just got round to fitting it so cannot get it changed.
Has anyone come across this before? Can I get a different connector for the newer unit?
Thanks in advance
Mike
:confused:
rsscotty 03-03-2018 12:49 AM
New style reference connector
You can buy the connectors, contacts, and seals.
electrical connector 99965291640
electrical connector for plug 99965287122 (3 required)
electrical connector seals 99965381140 (3 required)
Make sure you use the proper crimping tool.
Numbers are marked on new connector pin.
1 is signal
2 is 0 volt
3 is shield
rsscotty 03-03-2018 01:13 AM
New style connector
http://forums.pelicanparts.com/uploa...1520068343.JPG
MichaelS911 03-03-2018 07:32 AM
Thanks Guy. Much appreciate the help
Mike
