Big red and 15' / 16' Front wheels
Hi all, have you found one wheel in 15' or 16' that we put on the front off a 64 car?
3 parts wheel i think?
if yes, some links to see?
thanks
Old 03-23-2018, 09:41 AM
Cobalt's Avatar
If you are asking will a 15" or 16" wheel fit over big red brakes the answer is no. You will need a 17" dia wheel and the only three piece wheel used by Porsche is an 18" speedline.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-24-2018, 04:01 AM
yes, i have 17 cup1 and 18' mad'in, they fit without problem.
tryed yesterday with D90 wheels, and 12mm spacer > ko, i think that ok with 20mm spacer.
but, in 15' 3 parts wheels, i'm sure we can put in with big red brakes.
what kind aff theses wheels have you for sale in US?
Old 03-24-2018, 04:35 AM
Cobalt's Avatar
If you measure the distance from the hub center to the outermost point of the caliper I read 7" or 14" dia. So assuming you can find a 15" wheel with a flat inner profile that will only allow you 1/2" of clearance and no room for air flow. I'm not aware of any 15" wheel that has a flat inner profile although I have heard of some custom made 16" wheels that just fit but as I recall they had issues with overheating as well.
Sorry I can't help you on a make.
Old 03-24-2018, 05:09 AM
you are right Cobalt, it's 7' and i think more 7.05' to be fine ...
yes, i have ask for Mad'in and Tramont custom made wheels , for 15 and 16'.
i post it when i know exactly what they can offered
thanks
Old 03-24-2018, 05:21 AM
