-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   While You're In There - Engine Out (http://forums.pelicanparts.com/porsche-964-993-technical-forum/989928-while-youre-there-engine-out.html)
mcinturff 03-08-2018 12:43 PM
Hi gents, I have the engine/transaxle out of my '92 C2 to replace third gear in the G50. I've taken all the "tins" surrounding the engine off to be painted, they are in poor shape!
I was wondering what items I should look at replacing while the engine is out. I plan on replacing the housing and camshaft seals for the power steering pump, the belt, and possibly replacing the internal pump seals if I can source them. I've already ordered a plug wire set, going to do the plugs at the same time (and valve lash, of course). Any other wear items or leak points to worry about?
Thanks in advance!
JJ 911SC 03-08-2018 03:55 PM
BTDT, first thing; increase your Line of Credit :D:):D
faverymi 03-08-2018 05:21 PM
Honestly set a budget and lets us know.
The list is never ending with a set a budget at least you have a limit.
wesleyc 03-09-2018 06:34 AM
Add Timing chain cover gaskets. .. and like previously mentioned. The list can grow exponentially.
mcinturff 03-09-2018 12:26 PM
Fair enough, I'm not looking to spend a fortune, just maybe a couple hundred bucks in maintenance items.
2.7RS 03-10-2018 04:57 AM
964
This guy had pretty deep pockets.
Couple of hundred bucks will get you nice cleaning chemicals and plenty of rags
You get the idea of the extent of the work. They are almost 30 y/o cars
https://rennlist.com/forums/964-forum/898981-964-c4-light-refurb.html
mcinturff 03-10-2018 11:58 AM
Wow! That's one hell of a project!
John McM 03-12-2018 02:46 AM
I stumbled on this thread. What can I say but the Project got away on me :)
turbo ride 03-13-2018 01:54 PM
Look closely at your oil lines. I am about to have the 3.3 in my '91 Turbo reinstalled after a complete motor tear down (split case) - everything in the motor itself was in amazing condition at 95,000 miles except for the exhaust valve guides, by the way.
But we replaced a number of oil lines. So give them a thorough inspection. Will be a good time to replace the plugs, adjust valves, do the power steering pump seal and o-ring, check the seals at the "triangle of death" - that's what come to my mind
RS America 03-25-2018 07:31 PM
If you have over 60,000 miles, replace the O2 sensor. So much easier than with engine in. Wash/wax/detail engine compartment.
