TAV TAV is offline
WOT throttle body cam
Hi all
My throttle body cam is broken... so looking to see if there has been any aftermarket ones made that are metal? Or even just an OEM replacement?
Old 01-29-2018, 02:13 AM
964TargaC2's Avatar
Check this thread at Rennlist
https://rennlist.com/forums/964-forum/291266-source-for-wot-cam-actuator-needed.html
I think that maybe I'm dreaming..
Old 01-29-2018, 03:28 AM
TAV TAV is offline
Originally Posted by 964TargaC2 View Post
Thanks! I’ve seen this one. May be an option I go down re: drill and thread wire. Was hoping to get the metal fabricated piece, but not liking my chances of getting in contact with that guy.
Cheers
Old 01-29-2018, 03:35 AM
I ordered one from https://rennlist.com/forums/members/112436-soderblad.html
No problem.
Old 01-29-2018, 04:47 AM
TAV TAV is offline
Originally Posted by 540964 View Post
Thanks. I’ve tried to get in contact with him, but haven’t heard back. When did you order yours?
Old 01-30-2018, 01:51 AM
It’s been a couple years. The first package (a padded envelope as I recall)had a hole and was empty. I emailed him and he shipped another.
Old 01-30-2018, 04:03 PM
964TargaC2's Avatar
Give him a few days to respond, i got mine a while back, he makes these himself
Old 01-30-2018, 05:04 PM
Any luck reaching the guy who makes these? If not, any machine shop should be able to make one for you or you may want to try making one yourself out of aluminum. The trick of course is the hole with the flat. Easy to mold but hard to machine. I would consider drilling and reaming the hole to its full diameter and then drill and tap for a setscrew that will bear on the flat on the shaft it mates to.
Old 03-16-2018, 08:07 AM
TAV TAV is offline
Hi Torqhead.
No luck at all, but I actually went and did exactly what you suggested.
Here’s the end product....
Old 03-16-2018, 01:48 PM
nice work
Old 03-16-2018, 11:40 PM
Hi Torqhead.
Glad to hear that it worked out. Nice job!
Old 04-14-2018, 10:44 AM
