1990 964 C4....Was Headed Towards Being A Future Barn Find
Hello- Was hoping to get some opinions on what you would do in my situation.
I am in the process of buying my first 964, a 1990 C4, and hope that I have saved it early enough that getting her back on the road won't be a huge ordeal.
The car was garaged (uncovered) between 4 and 5 years ago (has 2014 expiration plate) by the original owner due to his poor health. He has since passed away. He was a well off medical doctor so I a hoping that he kept up on normal maintenance, but so far I haven't gotten any documentation from the estate. They are still looking for it.
By the first week of July I have to transport the car from the Midwest to my new house in North Florida. I would really love to have it driving and reliable by then.
So here are my thoughts.
#1- Inspect for any obvious liquid leaks or other issues
#2- Detail Interior and Exterior to get all the storage dust off and protect the paint during the mechanical work
#3- New Battery
#4- Drain all the fuel and replace fuel filter/s and add new fresh fuel
#5- Drain oil & Replace Oil & Filter
#6- Replace Air Filter
#7- Try to Fire It Up??
Am I totally off on anything? Should I add a tad of oil in the cylinders and hand turn the motor first?
After I get it running I will inspect the tires, but I am guessing they are shot having sit in the same spot 5 years?
Thanks in advance.
Old 05-09-2018, 12:15 PM
Old 05-09-2018, 12:28 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and congrats on the future purchase! Looks like a really clean overall car on the inside. I'm sure other members will chime in with their thoughts and opinions; but I found an earlier thread where your inquiry was discussed. Hope it helps you out a bit and best of luck! Keep us posted on the restoration process.
Just bought a 1990 911 c2 , been sitting 4 years, things to do to start??
Old 05-09-2018, 01:02 PM
Thanks Dimitry. Youíre right thatís pretty darn close to my question. Missed that on my search.
Old 05-09-2018, 01:44 PM
KNS KNS is offline
Your list covers all the important items. It certainly wouldn’t hurt to put a little oil in the cylinders. Try to turn the engine over by hand.
The tires will be fine for short drives around the neighborhood, I wouldn’t get on the freeway with them though.
Kurt
1984 911 Carrera
Old 05-09-2018, 06:47 PM
- Drain the fuel, add fresh fuel. Do not change the filter yet. Change fuel filter later when you get it running.
- Be careful when connecting a new battery that you don't cross positive and negative cables.
Crossing cables can destroy electronics.
- Flush the brake system later and inspect brake hoses for cracks.
- Check transmission gear oil level
- Before firing it up, remove DME relay and crank until you get oil pressure.
- Install DME relay and fire it up.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 05-10-2018, 08:57 AM
As bazar said, pull the DME, crank a few times, replace, then try to start it.
-TJ
C2 Coupe
Old 05-17-2018, 06:20 AM
I am in the Midwest - Madison, WI - if you need local eyes on the car for any purpose. Loading, inspection...as long as it is close to Madison.
Did you notice the cool radar detector under the dash? Vintage cool!
bazar's fire-up advice is all legit assuming oil on dipstick looks good. I always dribble a little out of the crankcase looking for water - but she's air-cooled. Once running and warmed up, then oil and filters.
I'll bet it fires right up and eventually she'll be a peach for you!!
Old 05-23-2018, 11:56 AM
Hey.......... save yourself a ton of problems, time and massive headache's... rent a U-Haul trailer and tow it back to Fla.
Ron
Old 06-23-2018, 09:01 AM
