Nine9six's Avatar
Brake/Clutch Slave/ABS/ABD System Bleed
It was time for a brake & clutch slave bleed, so I thought I would conduct an experiment using the PIWIS (KTS650), I recently purchased...I bled the braking and clutch slave systems in a typical fashion using a Motive Power Bleeder, bleeding an additional pint of fresh fluid through the system.
Subsequently, I hooked up the PIWIS, under the subheading of ABS/ABD, and used the "bleed" command 3 times, and then went back under the car and re-bled the clutch slave...
Back in 2013, I bled the brakes and clutch slave with my last can of ATE, super blue; and have since bled the system twice with the golden colored, ATE 200...
I wish I would have taken a photo of the bleed results after exercising the bleed command of the ABS/ABD system with the PIWIS, because the blue/black fluid that bled through the clutch slave system, was a fugly sight to behold!
To the SoCal Pelican community, or any out-of-staters, who happened to be in the SoCal area, I am offering, for a very reasonable fee, ($40), (to help offset a very expensive, Porsche specific diagnostic tool), to bleed your ABS/ABD system, if you are soon going to be bleeding your brakes.
The service I am offering is only to bleed the ABS ABD system within the brake system, and does not include a brake or clutch slave bleed of the vehicle . (964/993/996...)
Anyone interested, can contact Paul via, nine9six@gmail.com
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-06-2018, 03:20 PM
Cemoto's Avatar
That is a deal!
Al
Old 06-06-2018, 04:41 PM
Nine9six's Avatar
Thanks for the support, Al !
96 993 C2 (Current)
Old 06-26-2018, 07:15 PM
