Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
1999 engine into 2001 996..how, problems?
What is the possibility to put a 1999 engine into a 2001 car?
Here is the info......
The 2001 VIN is WPOAA29911s621767.
Attached is the serial of the 2001 bad engine.
Also attached is a picture of the details of the 1999 engine.
Has anybody done this?
Old 06-27-2018, 06:56 AM
engine swap
Pictures are attached
Old 06-27-2018, 07:01 AM
3.4 Bigger is better
88-diamondblue's Avatar
Check over on Rennlist for this. It should be a direct swap since they are 996.1 engines. Nothing changed much with the engine between 1999 & 2001. Major PITA going from 996.2 to 996.1. Or the other way around.
Michael
04 996 40th Anniversary
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2016 Acura RDX
Old 06-27-2018, 12:44 PM
Does the 99 engine have e-throttle? If not-you will have to swap over the intake from the later engine.
Old 06-28-2018, 03:37 AM
JFP in PA's Avatar
It is more than just egas, the 1999 engine used a 5.2.2 DME, the 2001 car carries a 7.2 DME.
Accrochez-vous bien de vos rÍves..........."
Old 06-28-2018, 07:28 AM
