-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   Brown Cam Plug popping out (http://forums.pelicanparts.com/porsche-996-997-991-forum/1004814-brown-cam-plug-popping-out.html)
paulgentile 08-13-2018 05:29 AM
My brown cam plug has popped come out twice, with only 4,000 miles in between occurrences.
Had a new one replaced and it seemed to go in quite easily. IMS has been done.
Is there any reason why this would occur?
JFP in PA 08-13-2018 07:37 AM
Two known causes for cam plugs popping: Too much sealant was used when reinstalling the cam covers, causing the adjacent oil return to plug and the oil pushes the plug out; or the AOS is not working properly and the crankcase is experiencing pressure rather than vacuum, which is popping the plug out.
Just as a "by-the-by", never use any type of sealant on the cam plugs.
paulgentile 08-16-2018 04:20 AM
Thanks! AOS was replaced and seems to check out. Likely the other. On the by-the-by, my mechanic did put some sealant on the new plug. Should I replace the plug?
JFP in PA 08-16-2018 07:09 AM
Yes, and clean all of the sealant off the cam cover as well. These were designed to be installed dry, meaning no sealant of any kind.
yelcab1 08-17-2018 01:44 PM
You do need a thin layer of silicone between the cam cover and the head, because there is no gasket. Am I wrong?
JFP in PA 08-17-2018 02:26 PM
Yes, but only a very thin bead or the excess sealant can get into the oil returns, causing oil to flood the cam cover and blow out the cam plugs.
There should never be any sealant on the cam plugs.
991gts6s 08-20-2018 05:45 PM
back in the day when i had the 996.. the cam plugs leaked and popped out ..
after the the vario cam guide replacement. instead of redoing the cylinder head sealant .. i put a little rtv( Porsche spec brand i forget the brand now)on the plugs and they never gave me a problem ever
JFP in PA 08-21-2018 10:03 AM
Very bad idea, they are designed to be used without any type of sealant.
Jeff Alton 08-23-2018 06:03 PM
^^^^ this.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
