-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   P1266 04 911 40th AE (http://forums.pelicanparts.com/porsche-996-997-991-forum/1004945-p1266-04-911-40th-ae.html)
59 Racer 08-14-2018 01:38 PM
Had a p0336 crankshaft position sensor code replaced the sensor code came back up no check engine light just a stored code . At 5040 RPM's the car shuts down in limp mode . Check engine comes on want take the gas . Stop restart car then car drives good till you hit 5040 RPM's .The code P1266 comes up .Talked to local dealer and a independent shop both agree replace ECU. Replaced the ECU with a rebuilt on from Specialized ECU Repair . They could not find any faults with mine but I still bought a rebuilt unit . The same code comes back with the rebuilt unit P1266 and the car shuts down at 5040 RPM's . We did a IMS bearing , complete clutch flywheel ,plugs replacement water pump , new starter ,starter wiring harness from alternator to starter . No miss fire codes no miss fires no cracked coils . Coils are the newer bigger ones .Any suggestions on what is the problem ?
JFP in PA 08-14-2018 06:19 PM
P1266 was the code for an implausible signal from the fuel shutoff monitor. Supposedly, this was fixed by a DME reflash with updated software many years ago.
matt demaria 08-24-2018 12:12 PM
Saw this on another 03 a few months ago. customer replaced flywheel and bent one sensor tooth inward. Scope sensor pattern at 5k; look for a dropout between the 2 tdc's displayed.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
